NI TestStand
Finding the name of my teststand sequence in the process model
I would like to be able to find the file path and name of a teststand sequence in the process model. I have created a simple vi which will display this information when run in a sequence. If i insert the vi into the process model, the file path and name returned is that of the process model and not the sequence under exectution. Is there a way of extracting this information in the process model?
(2,768 Views)
Davepar -
If you are executing in the process model you can use the following as a lookup string if you are in the root context "RunState.ProcessModelClient.Path" or "RunState.Root.RunState.ProcessModelClient.Path" if you are not in the root context.
Scott Richardson (NI)
Scott Richardson
(2,768 Views)
