03-18-2010 06:53 AM
I am using TestStand 4.2 and MySQL server for database logging.
A lot of test stations are sending results on-the-fly to this database through local network during more than one day.
These results are important and shoud not be loosed (IC characterization).
If the sequence does not complete, the UUT_RESULT entry is not filled.
STEP_RESULT are stored into databse but they are linked to a UUT_RESULT record containing only 'NULL' field'.
We need to be able to access to the results even if the the testbench has freezed or if the connection to the server has been loosed.
What could be the best solution to have a UUT_RESULT entry :
> saving periodicly the UUT_RESULT (the status will be unknow and the execution time will change at each saving operation) ?
> saving locally UUT information and send them to the database through a recovery procedure ?
Any other idea is welcome.
Jean-Louis SCHRICKE
├ CTA - Certified TestStand Architect (2008 - 2022)
├ CTD - Certified TestStand Developer (2004 & 2007)
└ CLD - Certified LabVIEW Developer (2003 & 2005)
03-24-2010 05:17 AM
I see that you have found the answer to your question in an other forum post. For all other users, below is the link to the forum which gives some elements of response :
On the Fly report fills UUT_RESULT informations at the end of the test
Charlotte F. | CLAD
National Instruments France
03-26-2010 04:39 AM
Ha Jean-louis,
ca me fait plaisir que ce sont pas que "les nuls" qui viennent ici pour chercher un peu d'avis! 😉
Sebastiaan Verpoest
STE - Zaventem
