09-17-2008 06:47 AM
I need to write several arrays to my report file. This works fine for a couple of times, but when I add to many steps I get the message "Failed to save sequence file xxx.seq. Out of memory" from the Sequence Editor.
I found the "CustomActionStep" on this board and modyfied it to handle two arrays.
Any ideas to why this happens?
09-30-2008 01:51 PM
Hi misa37,
I have run your sequence file several times, but I am unable to reproduce the same error message. I opened the sequence in TestStand 4.1, added 6 copied steps to the ones already present. My computer has 2 GB of RAM, with 20GB free of hard disk space.
If you open the task manager while the code executes is there a noticeable CPU spike or rise as the code executes? Have you tested this code on a different computer that has more RAM? What version of TestStand are you using?
10-01-2008 12:59 AM
I deleted the CustomActionStep and started from the beginig. Now everything works as it should. I don't know what happend, but it's gone now.
Thank you for trying to help 🙂
