09-05-2013 08:32 AM
I am using IVI driver to communicate to Keithley 2750 and read temperature from thermocouple,Type-K sensor.
I get an error -30717 (Extension capability not supported by Instrument(Temperature) when trying to read temperature.
I am able to read voltage,current and resistance directly by configuring IVI DMM from NI TestStand.
Please not that I have configured instrument for measuring voltage,current and resistance successfully. So I believe the initial set up and configuration are alright.
However I am not sure if this error is because of me not configuring the IVI step in correct order. I have attached screenshots of step configuration that I do.
Please provide any suggestions.
I have already posted this issue in Keithley forums. I have not heard from them yet.
Please find screenshots attached.
Please find the link for driver that I am using here: http://www.keithley.com/support/data?asset=52764
Sahithi
09-05-2013 08:34 AM
Here is the screenshot of error
09-05-2013
10:41 AM
- last edited on
05-06-2026
11:07 AM
by
Content Cleaner
Hey Sahithi,
This is likely related to a known issue that can occur with the IVI drivers when the instrument doesn't support all three temperature extensions (Thermocouple, RTD, and Thermistor). See more information in the TestStand Known Issues list here: https://www.ni.com/en/support/documentation/bugs/12/archived--teststand-2012---2012-sp1-known-issues...
It's possible that we could work around this issue by using an external code module to access this functionality. For example,you could create a LabVIEW VI which performs these operations, and call that VI from TestStand. Does this seem like a workable approach for your application? Another possibility would be to read the thermocouple as a voltage and perform the conversion to temperature within TestStand itself or with an external code module.
Let us know if there's anything else we can do to help!
09-06-2013 02:44 AM
I have already written a function to measure temperature of thermocouple using c# and calling that module in Test Stand; It works that way.
However, In order to minimize the coding that we do,I was keen to know if I am not configuring the driver correctly.
Thanks again.
