Hi Dennis,
Are you referring to the text displayed in the Description column that you see in the sequence editor?
This column is obtained from the Properties | General | Step Description Expression.
This expression is evaluated when the step is first inserted into the sequence. I guess the engine is handling this evaluation. If the engine can not evaluate the expression because for example the variable doesn't exist. a Message is displayed in the description column such 'The Step description step '
' could not be evaluated. Unknown variable or property....'
There is an example in the Resource Library which demonstrates displaying the result or / and the limits during runtime.
As a general comment on creating cUstom steps, especially the edit step VI. Alt
hough you are required to have an error out cluster on the connector panel. Errors seem only to be reported via this connector for the actual step vi. The edit vi, the pre step and post step vi's have to have any errors written direct to the step error properties before terminating the VI.
Also have you tried using the Combined with Step Type. Very useful if you want to expand a base step type
Regards
Ray Farmer
Regards
Ray Farmer
