I am using TestStand 2017 and LabVIEW 2018 f2. I have created this custom step type. Its edit VI works fine with LabVIEW Development System.
However, it throws an error when it's run with LabVIEW Run-Time Engine. The error comes from an ExpressionEdit property node in one of the sub VIs. If I disable the property node, no error occurs.
Why can't the run-time engine support the Expression Edit property node?
