NI TestStand
Expand/collapse icons are not visible
When I send the report to another person, the expand/collapse icons are not shown to him because the default absolute path is where the stylesheets are. Is it possible somehow to define my own absolute path so that I can transfer all those icons to another folder, zip everything together with the report and send it to somebody?
(1,182 Views)
You can use XMLPack to collect all the dependencies of the report in one folder.
XML Packaging Utility - TestStand Help - National Instruments (ni.com)
Anand Jain
NI
(1,163 Views)
Is it possible for the XML report to be generated using embedded icons to make it more portable (i.e. an octet stream, or other embedded object) so that only the report file itself needs to be shared, instead of using the XML Packaging utility? Maybe the answer is obvious, but I am not an XML stylesheet expert.
The same question also applies to the PDF report. I am currently having problems where my company logo does not appear in the PDF but does appear in the XML, however the expand/collapse icons do appear in the PDF but do not appear in the XML. How can I get things to work reliably so that both reports are always generated correctly with all of the relevant icons? I've tried a plethora of different ways of generating the reports using relative or absolute paths, putting the files in the TestStand public folder instead of install folder, putting icons in the report path or sequence file path, etc, etc. I also had issues with generating the HTML report (although I don't remember if it just mirrored the XML problems or if there were different problems). It would be awesome if someone could provide notes on a foolproof solution because the web and help files have not been that helpful.
(993 Views)
