Execution lock when reset USB buffer
Hi, I have write an application in Labwindows/CVI there ai read a serial USB port equepped with FT2232H.
The application runs with TestStand 2010 in debug mode.
My problem is that TSCVIRUN lock execution at the call FT_PURGE(handle, RX_PURGE);
Is some one there with the same problem.
Regards
(3,408 Views)
Does this happen with run mode?
YOu can post your query also in the CVI forum.
(3,301 Views)
