NI TestStand
Execution automatically loads to is ExecutionView when runstate changes?
I have a GUI with one TestStand UI SequenceView Control. I'm assigning this control to all of my executions like this:
I display the different sequences based on button press from the user. In a simple way if he hits button one then I load the execution of sequence 1 to the SequencefileView like this:
The problem I have is this: whenever a sequence changes its runstate (eg starts running, or gets paused) the given sequence gets loaded the sequencefile view. I tried to debug this four couple hours and I simply see absolutely no reason that my code is doing that, so I somewhat feel that this is done automatically.
Any chance that it is true? If so can it be disabled?
Thanks.
(416 Views)
Accepted by topic author 1984
It was like this because I built the TS part of my application by leveraging code from the TSUI shipped with TS as an example. In this the DisplayExecution Event Callback VI is used as a callback.
Removing that VI from the Application manager's Register Event Callback node solves the problem.
Kudos to me I guess...
(323 Views)
