Hi
I got a problem which im struggling to find a solution to.
What i got is a Sequence which calls two other sequence files using the sequence call step.
If the execution option of the sequence call step is none , the sequence is called and traceses correctly but when the Test is complete the viewer displays the main sequence trace and not the trace of the subsequence.
I need it to display the subsequence trace.
So i tried setting the sequence call step execution option to New execution , it shows in the viewer like i want it to but it does not place the information into the database.
How can i call a subsequence and display its trace for viewing after the test is complete(When using the operator sequence) and insert the information of the subsequence into the database?
Help share your knowlegde
