08-20-2019 07:14 PM - edited 08-20-2019 07:19 PM
I am using NI TestStand 2016 32-bit and DIAdem 64-bit on a PC with Windows 10 Pro 64-bit, when I try to use an ActiveX/COM action and when I select the Automation Server: DIAdem (Ver 1.0) the following error is displayed:
An error ocurred reading an ActiveX Automation server type library.
Error Code: -18351
[Refer to "Error 18351.jpg"]
I have the same software installed in another PC and here is working well, but here in the Automation Server appear as DIAdem (64-bit) (Ver 1.0)
[Refer to "ActiveX working well.jpg"]
I have tried to reinstall all the NI software and also I tried the following links, but I cannot fix the issue.
Any Idea? In advance thanks for the support?
11-07-2019 11:13 AM
I'd take a look at : https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019L0JSAU&l=en-US
