i changed my labview-adapter to runtime to get rid of the labview-popup while running in opui (TS4.0, LV8.5)
I get there an error:
Reserve loaded vi for executio = false
error -18001
an error occured accessing reserved loaded vis fore exec in lv adapter
fo
teststand adapter 4.0
unable to launch the labview.application. activeX automation server
Then i checked the box [X] reserve loaded vis for execution in the labview-adapter-settings (which was unchecked before).
After this i dont get the error again.
But: When i uncheck it again then the error is still not coming.
So, what was the problem here?
My OPUI is a custom-exe file created with an older labview-version.
To make i running in runtime, i had to masscompile my complete project-folder and to be sure i also masscompiled the complete c:\ProgramFiles\NationalInstruments-Folder.
Thanks for help
