02-16-2018 05:56 AM
I'm doing the training couse of teststand.
Could anybody help me with this error please?
Thanks so much.
02-20-2018 03:51 AM
Hi cristina.lopez,
this happens when the reference to the instument has not been properly closed.
When this error occurs, select Run Clean UP instead of Abort to make TestStand close the opened references properly.
04-08-2019 05:44 AM
I still have the Problem. I tried just to run the clean up , but does not work. Could you share how did you solve the issue with me please?
04-18-2019 03:48 AM
I have the same problem, can anyone help with it?
04-18-2019 04:20 AM
Did you highlight the Close DMM step in the Cleanup and then run Selected Step. Don’t run the whole sequence.
04-18-2019 08:12 AM
Do you have a Soft Front Panel for the device open? Or do you have a test panel in MAX open to the instrument?
If you aborted your TestStand sequence with an open session, it is possible that the resource was leaked. Try restarting LabVIEW and TestStand.
If none of that works, try rebooting the computer. The resource is clearly tied up somewhere, but a reboot is quickest way to recover.
If it does not work after a reboot, then the system is in a really bad state, and you should try working with the device in MAX to verify it functions normally.
04-19-2019 12:33 PM - edited 04-19-2019 12:34 PM
In the setup step of the main sequence, you have initialised DMM, Power supply and Scope.
Add value for DMM out = FileGlobals.Instruments.DMM
Power Supply out = FileGlobals.Instruments.PowerSupply
Scope out = FileGlobals.Instruments.Scope
Re-run the main sequence, and everything will be OK.
07-27-2020 06:47 AM
I got same error , but it is resolved by changing Power supply reference from "PowerSupply" to "Power Supply".
11-16-2021 01:09 PM - edited 11-16-2021 01:16 PM
I got it! I've been struggling with the same thing for a few hours.
The Initialize DMM is working fine. Its the Shut Down DMM that is not functioning properly for me. The "Synchronization" in the Shut Down DMM needs to be set to "Serial (one thread at a time)" or it will only close the first instance and future runs will fail.
PS: You may need to open the Shut Down DMM VI and use it on DMM0 and DMM1 before this fix will take effect.
