12-15-2021 11:17 AM
I tried to format a cRIO 9068 by command line following this discussion but this error appears:
umount: /mnt/userfs/run: target is busy.
/etc/init.d/mountuserfs stop failed with 0 (attempt 30)
ERROR: /etc/init.d/mountuserfs stop failed (30 attempts)
*** Error: /usr/local/natinst/bin/nisystemformat:186 (fn=umount_rootfs): Unexpected status code 1
(safemode) admin@NI-cRIO-9068-Name:~#
I also tried to format using MAX but with this error
Do you have any suggestion?
Riccardo
05-19-2022 05:22 AM - edited 05-19-2022 05:23 AM
same identical problem on MAX and on command line (for the same cRIO model too!).
Did you solve it somehow?
05-19-2022 06:04 AM
Suggest you to post this in hardware related forums and not in TestStand.
Maybe here :
https://forums.ni.com/t5/Multifunction-DAQ/bd-p/250
Ravi
05-19-2022 07:50 AM
I solved using labview 14 and related software to format and reinstall the cRIO OS. Then, I upgraded the system to labview 19
