NI TestStand
Error from Teststand on Labview Project
Hi NI,
I have the following error which I do not know how to solved and I have attached the screenshot
Any solution
How to correct this
(577 Views)
You are trying to call LabVIEW 2023 Files using the 2024 Runtime Engine
EIther compile your code to 2024 or install the appropriate 2023 Runtime Engine
(572 Views)
