08-03-2017 10:45 AM
08-03-2017 02:15 PM
What Step Type is Read Engine Speed? It looks like you have a custom step type and the sub step isn't set up correctly.
08-04-2017 08:32 AM
Read Engine Speed type is Normal channel value limit test
08-04-2017 10:25 AM
the same steps seq works properly on the other computer. So not able to figure what's the exact issue
08-04-2017 11:45 AM
Because that step type is installed by VeriStand and is obviously built on top of some .NET objects I think you should make sure that you are using the same version of VeriStand and .NET on both machines and that you installed the add on correctly.
I don't have VeriStand and haven't really used it so I can't test anything out for you. sorry.
08-04-2017 11:52 AM
Thanks dude.
I will try to uninstall and re-install teststand package .And will update the result
08-04-2017 11:57 AM
Not the TestStand package. The VeriStand package needs to be checked. HUGE difference. VeriStand has an add-on that installs some TestStand steps. That step type you are using is created by VeriStand and NOT TestStand. I doubt this is a TestStand issue.
