NI TestStand
Error coe -18351
Hi, When I load active component in teststand. Even though I register the DLL fine. But when I try to load in the Teststand. It gives me error -18351, saying loading activeX type information error. This DLL has been used on other machines and they all work fine. And I have tried to load/reload TestSTand, too. I do not know what else I could do.
I appreciate your help.
Na
(3,031 Views)
Hi Na
What adapter are you using to call your DLL in TestStand?  From your post, it reads like you are using the ActiveX/COM Adapter.  Is this correct?  Have you tried to use the C/C++ DLL Adapter to call into your DLL?
Russell G.
NI Applications Engineering
(3,016 Views)
