02-18-2021 05:10 AM
i'm using a sequence in teststand 2014 that contain a multitude VIs of mesure channel list.
this VI mesure many signals of my module card at the same time and stored into a variable numbers container in stationGlobals , but some times randomely it shows the error (Error code: -17324, Array index out of bounds).
i configure the variable as empty to record the measures dynamically.
I read in the documentation of "TestStand known issues" that (this error is more likely to occur if the invocations of the two selected steps specify a different number of calls.
Workaround: Modify the invocations of .NET steps individually.)
but i don't inderstand this perticular point.
Any help is appreciated
many thanks in advance
03-11-2021 03:27 AM
What you don't understand at the mentioned point? Please specify, do you use the mentioned call, or it's odd?
