Error code: -17324, Array index out of bounds problem for measur channel list
i'm using a sequence in teststand 2014 that contain a multitude VIs of mesure channel list.
this VI mesure many signals of my module card at the same time and stored into a variable numbers container in stationGlobals , but some times randomely it shows the error (Error code: -17324, Array index out of bounds).
i configure the variable as empty to record the measures dynamically.
I read in the documentation of "TestStand known issues" that (this error is more likely to occur if the invocations of the two selected steps specify a different number of calls.
Workaround: Modify the invocations of .NET steps individually.)
but i don't inderstand this perticular point.
Any help is appreciated
many thanks in advance
(1,008 Views)
What you don't understand at the mentioned point? Please specify, do you use the mentioned call, or it's odd?
(941 Views)
