11-07-2022 11:52 PM
On two new Teststand installations, I get this error, and Repairing the TS install doesn't help.
Nothing has been done on these systems other than install and opening the Sequence...
Details:
The prototype of member 'SequenceFileCache' in class 'ManagedModelSupport.SequenceFileCache' in assembly 'ManagedModelSupport, Version=19.0.2.49155, Culture=neutral, PublicKeyToken=null' depends on a type from assembly 'NationalInstruments.TestStand.Interop.API, Version=19.0.0.172, Culture=neutral, PublicKeyToken=ad9244eb3b825cd8', but that assembly could not be loaded (NOTE: To force a refresh of the information for this assembly, select the 'File->Unload All Modules' menu item.).
Error Code:
-17500; Operation Failed.
Step 'Create plug-in cache' of sequence 'Initialize Model Plugins' in 'ModelSupport.seq'
11-16-2022 04:54 AM - edited 11-16-2022 04:55 AM
I know that this is a funny question but have you tried turning it off and on again? I mean after the installation reboot is required (ok, maybe it is not required but it might help). After rebooting, you can try to open the version selector and "activate" your new installation. This part will properly register all dlls in GAC AFAIK.
11-16-2022 05:07 PM
Yup. Several times. Something must have gone wrong during the install. We removed all NI stuffs and then added all the stuffs back and it worked.
Funny enough, that was the very first time a google search turned up empty results for an NI error.
