09-30-2008 10:24 AM
When trying to build an installer in TestStand with run time engine, I get the following error:
***Error:Windows SDK function returned an error.(Error code -12)
***End Error Report
Even if I try to only create an installer for the TestStand run time engine I get the same error.
09-30-2008 11:29 AM
monaro,
This problem can happen when installer dependencies cannot be found. I found several forums that had steps to follow to try to resolve the issue:
http://forums.ni.com/ni/board/message?board.id=170&message.id=249866&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=170&message.id=307243&requireLogin=False
Let us know if after following these steps your issue is not resolved.
10-01-2008 08:05 AM
When I try to create an installer just of the TestStand run time engine , I get the error when I include DAQmx 8.7.
I am using TestStand 4.0.1 and LabVIEW 8.0. Currently I don't know what dependency it is looking for.
What would my best option be? I could create the TestStand run time engine and install it on the target machine.
I could separately install DAQmx 8.7 and the LabVIEW runt ime engine on the target machine. I could then install the
TesStand sequence files and supporting files on the target machine.
10-01-2008 02:57 PM
monaro,
To make it as easy as possible to deploy NI software, all software relies on the same framework. I believe that the newest version of the framework will give us a better error message and allow you to continue working on your deployment.
You can upgrade your framework simply by installing a piece of software that includes it. Try the LabVIEW 8.6 Run-time Engine. After you install this, you might get a better error.
Let me know if this doesn't help your situation and I'll see what other troubleshooting steps we can try.
