NI TestStand
Error : Win32 Handle that was passed to Icon is not valid or is the wrong type
Hello all,
i have an evaluation version of teststand and i can't open the seq editor
Any help with this please
Message 1 of 12
(6,711 Views)
What operating system are you running and what version of TestStand are you trying to run?  It would be helpful to get more of a context of your system.
DillonL.
Message 2 of 12
(6,660 Views)
OS : Windows 7
Teststand 2014 32 bit
i try to unstall all NI software and install again (C:\Program Files (x86)\National Instruments\TestStand 2014\Bin\SeqEdit.exe) but dosen't work always the SeqEdit.exe won't run .
any explanation of this error please
Message 3 of 12
(6,656 Views)
Is this something that has always occurred with this installation of TestStand or is this an error that appeared after the software was working for some time?
DillonL.
Message 4 of 12
(6,639 Views)
Thanks for your response, Yes it was working for some days and then SeqEdit won't run
so untill now i have tried uninstalled and reinstalled the software but that didn't solve the issue also i have attempted a force reinstallation of the software using command prompt and setup.exe, But i still have the same error
any explanation of the error ? other suggestions ?
PS: i'm always runnig as administrator
Best Regards
Ahmed
Message 5 of 12
(6,637 Views)
Hi Ahmed,
Can you try running the TestStand Version Selector and launch the Sequence Editor from there?
DillonL.
Message 6 of 12
(6,622 Views)
Hi Dillon,
I tried to run from the TestStand Version Selector but still same error
any other options please ?
Ahmed
Message 7 of 12
(6,619 Views)
Hi Ahmed,
Did anything change between the time you were running TestStand fine and the time where it stopped working? Software installation?  Update?
DillonL.
Message 8 of 12
(6,603 Views)
Hello Dillon,
Yes i installed other softwares but i'm not sure if this cause the problem
How can i verify and corrige this error ?
Ahmed
Message 9 of 12
(6,569 Views)
When you say the sequence editor wont run, does it give you any kind of error or does nothing happen?  If nothing happens, could the window be off screen for some reason?  Can you try the following steps as sometimes this can be something odd that happens:
Windows: Bring Off-Screen Window Back Onto Screen
https://www.technipages.com/bring-off-screen-window-back-onto-screen
DillonL.
Message 10 of 12
(6,562 Views)
