I'm making modification to the LV operator interface . Now I'm running a test unit in owr lab that is running constant. And they have several problems. At least once a day they are getting a message
`Not enough storage is availble to complete this operation in Test-Stand -Handle Trace Event.vi - Test-Stand.simple VI message Handler.vi`
When this message appears they can't go back and they have to reboot the computer. Note: The Handle Trace Event.vi was changed by adding several items.
And another problem that during the day the computer is getting slow and they have to reboot the computer again.
Have you ensured that there are no memory leaks in your code? Sounds like you may have a leak in your code. If you neglect to close references in your modified VI, you may be creating a leak. The computer is getting slower because you are running out of physical memory and you are swapping in your hard drive to make up for the low memory. You can monitor your resource use with a utility like taskinfo2000 and verify this.
Tak Yamada National Instruments http://www.ni.com/ask
It seems that this problem happens when i'm using short sequences a lot of times ,I double check my codes and didn't found any problems in memory leaks , the problem is happennig only if i'm running the codes in Teststand.
