When I try to Assembly VIs in TestStand I receive the message.-error 7 Invoke Node in TestStand-Dist Cmp Setting to Disk Hier.vi->Build Dist for TestStand.vi->TestStand-Packaged VIs for Distribution.vi->TestStand-Call Package VIs for Distribution.vi; and when I try to Build an .exe using the LabView of the same VI, get a similar error (7), and don't have idea how to correct this problem,
