12-23-2011 12:28 PM
I'm getting this message when I try to use a DotNet adapter in TestStand.
The instance of the .NET class could not be retrieved.
Object reference not set to an instance of an object.
Source: VTF at CPS.Engines.SelectCom.Stack.TransportLayerComms..ctor(GenericComms _physicalLayer, EngineLogDelegate _log)
at CPS.Engines.SelectCom.SelectComMasterEngine..ctor(GenericComms _comms, List`1 _supportedProtocols, EngineLogDelegate _log)
at CPS.Engines.SelectCom.SelectComMasterEngine..ctor(GenericComms _comms, ProtocolStack _protocol, EngineLogDelegate _log)
Error code: -17500; Operation Failed.
I have succefully ran this application in LabVIEW, using DotNet objects. I have attached both the Sequence file (which errors out, and the Labview application, which works.
Hoping for any help I can get.
01-03-2012 10:04 AM
I'm assuming the step you are getting the error on is the one that constructs the SelectComMasterEngine (i.e. ContructSelectComMasterEngine). Is this correct?
I see two potential problems with that step:
1) The argument you are passing for the first parameter is not the one you set in the first step. You are passing FileGlobals.CommsSetting rather than Locals.CommsSetting. FileGlobals.CommsSetting is likelly a null reference.
2) You are passing in a variable for the _log parameter that is also potentially unset. At least I don't see anywhere where it is getting set before it's being used.
Hope this helps,
-Doug
