NI TestStand
Error 17500 Binary file not found
Out of nowhere a error occurred in the TS sequence file which wouldn't run afterwards. I googled with the error code of 17500 but the descriptions were different. Please see if you could help me out with the attachment be767621-d9b3-45bc-9f5a-cdb75a8f9d4e.JPG
(2,562 Views)
Hello.
According to the message - is there any chance that your file got somehow modified?
Do you use source code control?
What version of TestStand do you use?
Did you see that advice? https://forums.ni.com/t5/NI-TestStand/Shared-variable-in-Teststand-error-17500/m-p/1267624
Best Regards,
TK
Certified LabVIEW Architect (CLA)
(2,539 Views)
