Got a bit of problem with a Teststand deployment that I've found various answers for on the discussion forums, but not any that appear to fit my particular one, so hoping someone out there might be able to help.
We are using the Teststand runtime engine with a Labview front end.
If we startup our system, login as a restricted user then start our software everything is fine - no errors at all.
If we startup our system, login as Administrator then start our software we get the attached error indicating that Teststand either can't find a dll or, or can't load it, and as I've checked for all the dlls it mentions and they are all present - it looks as though it is having problems loading them.
This seems to fly in the face of what you would expect - generally with installations it is the restricted user who has the problems running sometimes restricted dlls/exes, and it is even more strange in this case as we did the install as Administrator, so again you would expect any dll load problems to occur with a restricted user.
Anyone got any thoughts or ideas about why this might be happenning?
David Clark
CLA | CTA
IDEX Biometrics UK Ltd
Hampshire, England
