NI TestStand
Error 17001 - the sequence file pointer is invalid
Hello everybody !!
In a sequence file, I call a DLL (with MFC) without any problem. It works pretty good, but when I want to close the sequence file editor, errors occur :
System level Exception
Error Code :  -17502
following by
The sequence file pointer is invalid
Error Code : -17001 program error
After, there's no way to exit the sequence file editor without killing it.
Is there any C++ syntax code that TestStand doesn't understand ?
Is there special code line to include into the DLL ?
Thank you for your answers.
Have a nice day.
MrOrange
(2,995 Views)
Have a look at the example
.....\TestStand 3.5\Examples\AccessingArrays\PassingSequenceContextToMFCDLL\AccessingArrays.seq
to see where you might be going wrong.
Or post your code or an example of your code that shows the problem.
Regards
Ray Farmer
Regards
Ray Farmer
(2,988 Views)
Thanks a lot.
With NI sequence file example, about using MFC and DLL with TestStand, I succeed in debugging my sequence file.
extern "C" {
//your code
(2,968 Views)
