Equivalent to Step.Limits.Low.NumericFormat in TestStand 3.1?
...and everything comes into focus.
Thanks Doug.  I appreciate your time spent on this.
Message 11 of 23
(2,005 Views)
Hey Steve, the picture of your solution seems to have gone missing, any chance of reposting it?
Message 12 of 23
(1,917 Views)
Hi Jon.  I have no idea where the images are Smiley Mad.  I have reported the missing images to the NI Moderator.  Hopefully they will reappear at some point.
Message 13 of 23
(1,910 Views)
Thanks for the quick reply. Maybe you can answer another way: when I call GetPropertyObject on the step object, what do I pass into the lookupString? "Limits.Low", so that I have to also set "Limits.High" separately? The TestStand step settings seem to suggest that there is a single format that applies to both limits but that might just be a convenience)
Message 14 of 23
(1,908 Views)
Yep. Using the reference to the Step call AsPropertyObject and then use "Limits.Low" and "Limits.High". I have always done them separately, but that is based more on me finding a way that works and sticking with it rather than investigating further to see if there is a better way (setting them using a single call). I have attached an image from further up in this thread, that shows the sequence of calls in LabVIEW.
Message 15 of 23
(1,900 Views)
Attaching images is not working, Jon check out page 1 of this thread for the Set Step Limits.png image.
Message 16 of 23
(1,892 Views)
Well I may be daft but I don't see anything related to setting step limits in that link, though I did amuse myself looking through some of your posts!
Maybe it takes a while for NI to generate a new page?
Message 17 of 23
(1,888 Views)
The link at the bottom of my posts is to my blog, ignore that, it appears at the bottom of all my posts.
Here is the image I was talking about, for some reason image attachement is now working.
Message 18 of 23
(1,882 Views)
Oh, sorry, you meant the picture on page 1 of *this* post, silly me. However that only shows me what I have already got working, it's the NumericFormat bit that I can't quite get how to do.
BTW your blog post "FOR Loop Count (N) Terminal" of 01-07-2016 has been answered incorrectly by everyone, I guess because the picture got lost and has been incorrectly reconstituted ... unless I really am daft!
Message 19 of 23
(1,870 Views)
I take it back about the blog post, I guess the 4th element of the array is empty, right? It's hard to see that on the pic.- LabVIEW shows a much more faded colour. Anyhow, sorry to go off track!
Message 20 of 23
(1,868 Views)
