06-09-2016 09:21 AM
Hi
Is it possible in Teststand 2014 to locate the process model by using a enviroment variable ?
I have created a enviroment variable <TestsystemModel>
When i go to Configure > Station option > model > i want to set <TestsystemModel>\Mymodel.seq
Thanks in advance
Tonnie
06-28-2016 03:45 AM
Hi Tonnie,
How is your application coming along?
I just wanted to clarify a couple of points in your original forum post:
1.) By "locating the process model", are you referring to actually finding what process model you are using? Or locating the file path of where a particular process model is located?
2.) By "environment variable", are you referring to Windows based environment variables, are ones from within TestStand? Is there a particular environment variable you are aiming to use to complete your required functionality?
Kind regards,
Hashim Shamsi
06-28-2016 10:07 AM
Hello HashimS
I have still not found a solution for the enviroment variable
By "Locating the process model" i mean the path to the process model
With "Enviroment variable" i mean the windows enviroment variable.
I want to locate the process model via a enviroment variable
For instance <TestModel>\Myprocessmodel.seq where <TestModel> = C:\CompanyName\Models
06-28-2016 10:27 AM
Hi Tonnie,
Since reading your forum post, I have conducted some research of my own as well as talk to some of my colleagues who have a lot of experience with the TestStand environment.
Unfortunately, it looks like that this is not possible within TestStand using an environment variable.
May I ask what your application is and why you require to do this in this particular way? Perhaps there is a work around to this sort of problem.
Kind regards,
Hashim Shamsi
06-28-2016 10:28 AM
Hi Tonnie-
It is a unclear why you are attempting to locate the path to the Process Model file from a Windows Environment Variable. Would you explain in more detail what you are trying to achieve with this approach?
More generally, you can access the path to the Process Model file path in several ways (depending on context):
1. Within the context of an Execution - use the ModelSequenceFilePath property (e.g. Locals.ModelPath = Runstate.Execution.ModelSequenceFilePath)
2. To access the Station Model SequenceFile object - use the Engine and call the GetStationModelSequenceFile method (e.g. Locals.ModelPath = RunState.Engine.GetStationModelSequenceFile(Locals.ModelDescriptionString).ModelPath)
3, To access the currently configured Station Model specificed in your Station Options - use the StationModelSequenceFilePath Property (e.g. Locals.ModelPath = Runstate.Engine.StationOptions.StationModelSequenceFilePath)
This list may not encompass all possible ways to access the Process Model file path for a given context. However, this should provide you with some direction.
-Jeff
06-29-2016 06:01 AM
Hi Jeff
The reason i ask this is the following
When we install a new test pc we make use of an unattended install for the operating system and for the national instruments software.
We would like to install a enviroment variable on each testsystem with the path to the processmodel on the network.
For instance <TESTSYSTEM>\Processmodel.seq where <TESTSYSTEMS> = J:\CompanyModels
Then the location changes in the future we want to update all testers automaticaly by changing the enviroment variable.
Tonnie
01-26-2017 12:37 PM
Hi Tonnie,
Sorry if this response comes late. I'm working with a similar setting hope this helps you.
What you need to do is to change the reference of the TestStand Public Folder, to do this you need to change the registry, and you can do this as following:
How to Configure a Custom Public Directory for TestStand 4.1 and Later
I tested it with TestStand 2014 and using another driver (N:\) and is working. I also checked the Enviromental Variables for TestStand:
TestStand -> C:\Program Files\National Instruments\TestStand 2014
TestStandAppData -> C:\ProgramData\National Instruments\TestStand 2014 (32-bit)
TestStandBin -> C:\Program Files\National Instruments\TestStand 2014\Bin
TestStandPublic -> C:\Users\Public\Documents\National Instruments\TestStand 2014 (32-bit)
After I made the changes and directed the Public Folder to N:\, it seems that it's ignoring the Enviromental Variables and using the registry path. So your Process Model could be in the Public Folder.
Hope this helps!!! And sorry if it's late.
Tania
