NI TestStand
Enable/disable Comport from PC using Testsand/Labview
I would like to do, Re-scan method in Teststand
Tasks:
1. want to see all connected comports
2. Then I will selelct which component I need to disable/eject.
3. Then again, I will install that disabled comport.
4. Again, I want to see all connected Comport
Please guide me through it, if you have a solution
(762 Views)
This is no particular TesStand issue….
from what you describe, you might want to check MS Pnputils from TestStand
(759 Views)
Thank you for the reply,
Could you please let me know how I can do that? Any link/ reference or short description?
I have never worked with Ms Pnputils
(753 Views)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA0VU00000006zt0AA&l=de-DE
gives a brief introduction. Though this article refers to USB devices, most of it is applicable for COM interfaces as well.
I recommend exploring this to learn from it.
(726 Views)
As stated previously, this is not exactly TestStand's purpose.
If I understand correctly, you have an issue with your drivers getting corrupted throughout the sequence you're running? If so, it would be more beneficial to look for the root-cause of your drivers getting corrupted.
(695 Views)
