NI TestStand
Effect of different rows of NI SCXI 1130 on each other
Hello
I have NI SCXI-1001 Chassis with NI SCXI-1130 switching slots. What  I am going to do is: generating a signal by a RIGOL Function Generator and switch this signal to excite some piezoelectric sensors and reading the response signals by a Tektronix oscilloscope.
The problem is that when I connect both of the function generator and oscilloscope to different rows of the matrix I see the actuating signal in the response channel of oscilloscope, but when I connect one of the function generator or oscilloscope to the matrix and the other one directly to the piezoelectric there is no problem and I have the correct signal. What can be the problem?
I'll be thankful if you could help me
Saeed
(3,635 Views)
I think you should ask this question in the PXI forum (this forum is for TestStand users).
http://forums.ni.com/t5/PXI/bd-p/270
Ravi
(3,276 Views)
Thanks for your help Ravi
(3,273 Views)
