Are you trying to set the fileglobals of an executing sequence file or of a sequence file that is opened but not executing? There are different ways to accomplish either.
jigg CTA, CLA testeract.com ~Will work for kudos and/or BBQ~
You access file global variables using RunState.SequenceFile.Data.FileGlobalDefaults.myVariable. You will insert the name of your variable in place of "myVariable". You can then set this variable equal to your desired value.
Adena L. Technical Support Engineer National Instruments
