06-06-2019 09:37 AM
Hi folks,
I've been battling with this issue for the last few days on and off, I really have no idea why it's happening, especially considering that the vi in question has been used before without causing me issues.
I made a deployment using the Deployment Utility using a Workspace File, I install from the Installer and when I run my sequence I get the following error, or a variation of it . . . (excuse the poor picture)
So RigolIO is a Container Type Def
containing a String, Number, Number and an Enum called Rigol_IO_In_Out_Type
The vi in question, has the following Type Defined Cluster:
containing the following Type Defined ENUM called In/Out Type
Everything looks OK to me, when I run my sequence in the development environment it all works without error, I've previously used this vi with another Sequence and Deployed it without issues . . . now all of a sudden I can't get it to work.
I've tried creating a small Sequence which is a small part of my original sequence, I recreated the Container and ENUM,made a new Workspace file and deployment, after installing again and running the sequence I get a similar error, it just complains about a different value this time.
Any ideas ?
Solved! Go to Solution.
06-06-2019 12:07 PM
Sorry, should have mentioned the following:
TestStand 2016 LabVIEW 2015
06-07-2019 05:49 AM
It's looking like I might have a corrupt vi, I've created a new vi using the same EMUM and cluster, then created a new sequence and workspace file and installer and that works.
I'm recreating the suspect vi now and will build it into my original main sequence and build the installer and test again.
