09-02-2014 07:17 PM
09-08-2014 04:08 AM
Hi MimiKLM
My name is Jonathan & I work within the Applications Enginerring department at NI. Thanks for posting such an interesting question, it really got me thinking. I don;t know wheteher the best solution would be for you to incorportate C programming using LabWindows/CVI into Teststand in order to create a test sequence with easier programmable values. I have attached some information below which may be useful for your application.
Do you pay for any support from NI? As im sure that an Field Engineer would be happy to speak to you in regards to this.
I hope you find this information useful:
http://www.ni.com/pdf/manuals/375070a.pdf
http://www.ni.com/white-paper/14378/en/
https://decibel.ni.com/content/docs/DOC-37227
Cheers
J
09-08-2014 09:08 AM
Have you looked into Property Loader? It allows you to populate a container's data and can be used to populate only certain values. For example, you can load all the default values firstly. Then depending on specific product you are testing, you can replace specific values to customize it for your product. Thus kind of allowing it suport inheritance and nullable data.
Take a look here and see if this helps your problem. Help Link
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
09-10-2014 06:34 AM - edited 09-10-2014 06:35 AM
Hi Jonathan,
Yes we have support from NI.
Before I speak to Field Engineer I wanted to know what other members of the forum think about that.
I have a good feeling that it could be achieved if in TS developers could define the .NET types. I've posted the idea of it on the NI TS idea forum:
Thanks for the links to documentation.
bsvare, I don't want to use Property loader.
09-10-2014 09:57 AM
Hi MimiKLM
hat seems fair.
If you need any further assistance let me know 🙂
