NI TestStand
Don't charge multiple numeric limits!
Good morning to all,
      I have reading all topics but without success for my problem.
I have a test with a large number of callbacks to little subseqences.
Every subsequence have a property loader: it charges a multiple limit test (of 4 test each).
My idea was to permit the easy modification for this limits files, saving single file txt for each subsequence and reducing that to the minimum functionant format.
I omitted the
<Locals>
<FileGlobals>
<StationGlobals>
specifications .. and also the
Result.Measurement[0].Comp
parameter.
I've tried that in a litte test sequence and this really well work, but in the complete test sequence the limits files are well writted and saved after the front panel but limit remains the same imposted from the various subsequences!!!
I attached some txt property files.
I hope that someone help me!
Sorry for my english,
Stefano
(3,604 Views)
Dear Stefano,
I tried to use property loader in TestStand 4.0.1 with multiple numeric limit and seems to work.
Would you be so kind to check this example and see if it works also on your side.
Best Regards
FiloP
It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong.
Richard P. Feynman
(3,534 Views)
Thanks.  This was just what I was looking for Smiley Very Happy
Jim
(3,395 Views)
