NI TestStand
Do I need to use a LabVIEW OI with TestStand?
Hi All,
I'm working on a project which uses LV code modules within TestStand. It's been a while since I took my TestStand courses, and I never really used it in the interim.
When deploying a TestStand Sequence, do I need to use an OI? (like the examples provided) Or will I be able to run the TestStand sequence on the target machine itself, with just a generic OI?
I hope this makes sense!
(2,012 Views)
To run a Sequence File, no matter if you have LabVIEW, C# or other Code Modules, you can use TestStand Sequence Editor or OI (you can choose any implementation from examples, doesn't matter which technology you used to write your code). If you have LabVIEW Code Modules you don't even need to have LabVIEW installed. To use TestStand Sequence Editor you need debug or full licence.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,984 Views)
