NI TestStand
Displaying report text based on step result
For reference, I am using TestStand 4.0 and CVI 8.0
I have a CVI numeric limit test step where I would like to print out a report text message only if the step fails.  What I think I need to do is to set Step.Result.ReportText based on the result of the step.  It seems like using a post-expression or a post-action should work, but either I don't know how to use them for this purpose or neither one is capable.    It seems like setting Step.Result.ReportText can only be set from the actual step thats reporting so jumping to another step to perform the action is not an option.  I was also thinking that possibly the SequencFilePostStep engine callback could be overridden but I think that would affect all steps when I just want to affect a few.
Message 1 of 10
(6,507 Views)
What about using Engine Callback SequnceFilePostSepFailure ?
It is only called when a Step failed.
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 2 of 10
(6,505 Views)
That's an option, but it still affects every step that fails which complicates things.
Message 3 of 10
(6,500 Views)
HI,
OK, then i would try the Post Actions in the Step properties.
There you can select for example "On Fail" a sequence call.
See the exsample to attach the report text
Greetings
Juergen
--Signature--
Message 4 of 10
(6,487 Views)
you could also use the Post-Expressions.
With the following command in the Post-Expressions, you can delete the ReportText when your Step passed.
Step.Result.PassFail==True ? Step.Result.ReportText="" : Step.Result.PassFail
Greeting from Lake of Constance
Message 5 of 10
(6,462 Views)
Hi Schnurpsl,
a nice piece of code you figured out  !
It seems that I will use your stuff in future tasks. I 'll give you 5.
Greetings
Juergen
--Signature--
Message 6 of 10
(6,456 Views)
Just a note, Step.Result.PassFail is only available in the Steps of PassFail step-type. For NumericLimitType, you would have to use something else. You can't use StepResult.Status because this will not have been evaluated when the Post Expression is invoked.
Regards
Ray Farmer
Regards
Ray Farmer
Message 7 of 10
(6,442 Views)
yes you´re right. I just thought about the Pass/Fail Test.
But for a NumericLimitTest I´ve got another solution.
In this small sequence I integrated both Tests. To delete the ReportText at the NumericLimitTest, you have to use the Post Actions
Greetings
Message Edited by Schnurpsl on 01-30-2008 08:20 AM
Message 8 of 10
(6,433 Views)
Sorry, the first Sequence works only with LabView 8.2
This Sequence works without an adapter
Message Edited by Schnurpsl on 01-30-2008 08:36 AM
Message 9 of 10
(6,428 Views)
Thanks for your help.  I will try the ternary operator method first, it looks like that is a useful statement for the expression fields.
Message 10 of 10
(6,418 Views)
