NI TestStand
Display a Station Global in report
I would like to display the value of a station global in report ? How can I do ?
(3,998 Views)
Use the Additional Results step type or use the Additional Results property in a None Adapter Step Type.
Regards
Ray Farmer
(3,995 Views)
I have tried to add the additional results step but it does not work, see the attached file.
(3,993 Views)
The Name field is a String so make sure you have quotes.
Have you remember to enable Record Results for that step.
How do you mean "it does not work"? Are you getting errors?
Regards
Ray Farmer
(3,981 Views)
Here is an example using Additional Result Step type.
Regards
Ray Farmer
(3,979 Views)
Ok, thanks a lot ! It works.
(3,973 Views)
