Online shopping is currently unavailable.
Please contact us for help or try again later.
02-29-2012 02:58 AM
I would like to display the value of a station global in report ? How can I do ?
02-29-2012 03:07 AM
Use the Additional Results step type or use the Additional Results property in a None Adapter Step Type.
02-29-2012 03:16 AM
I have tried to add the additional results step but it does not work, see the attached file.
02-29-2012 04:12 AM
The Name field is a String so make sure you have quotes.
Have you remember to enable Record Results for that step.
How do you mean "it does not work"? Are you getting errors?
02-29-2012 05:10 AM
Here is an example using Additional Result Step type.
02-29-2012 10:04 AM
Ok, thanks a lot ! It works.
