NI TestStand
Display Incomplete executions dialog in C#
Hi!
I am developing a custom UI for testStand. From that application I need to invoke 'Incomplete Executions dialog' of TestStand if my application has incomplete executions and I try to exit the application.
I have used
_applicationMgr.Shutdown(); function to close application manager while exiting UI application.
Then dialog as given is displayed.
But I need to display 'Incomplete Executions dialog' of TestStand shown below.
Which API should I call in my application to display this dialog.
Please comment.
Thanks & Regards
Sgy1
(3,518 Views)
Hi
Pls suggest a workaround. Thanks
(3,415 Views)
You need to attach the picture (not BMP format) using the Add Attachments.
Regards
Ray Farmer
Regards
Ray Farmer
(3,412 Views)
Please find the images added as attachment
(3,409 Views)
Hi!
Image-1.JPG - is the dialog displayed in custom UI on calling applicationMgr.Shutdown().
Image-2.JPG - is the dialog displayed in TestStand.
Thanks & Regards
(3,407 Views)
Accepted by topic author Sgy1
Image2, I think is built into TestStand Sequence Editor and not one you can call from an API.
You can get all the Execution and find they names to display in a control and use the Execution.Terminate method to terminate that selected execution. or if none selected then use the Engine.TerminateAll method to terminate all executions.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,401 Views)
Hi!
Thanks for this valuable information. That was of great help.
Thanks & Regards
Sgy
(3,378 Views)
