10-10-2008 06:57 AM
Hi!
I am developing a custom UI for testStand. From that application I need to invoke 'Incomplete Executions dialog' of TestStand if my application has incomplete executions and I try to exit the application.
I have used
_applicationMgr.Shutdown(); function to close application manager while exiting UI application.
Then dialog as given is displayed.
But I need to display 'Incomplete Executions dialog' of TestStand shown below.
Which API should I call in my application to display this dialog.
Please comment.
Thanks & Regards
Sgy1
11-13-2008 01:00 AM
Hi
Pls suggest a workaround. Thanks
11-13-2008 04:18 AM
You need to attach the picture (not BMP format) using the Add Attachments.
Ray Farmer
11-13-2008 04:59 AM
11-13-2008 05:01 AM
Hi!
Image-1.JPG - is the dialog displayed in custom UI on calling applicationMgr.Shutdown().
Image-2.JPG - is the dialog displayed in TestStand.
Thanks & Regards
11-13-2008 05:52 AM
Image2, I think is built into TestStand Sequence Editor and not one you can call from an API.
You can get all the Execution and find they names to display in a control and use the Execution.Terminate method to terminate that selected execution. or if none selected then use the Engine.TerminateAll method to terminate all executions.
Hope this helps
Ray Farmer
11-13-2008 09:57 PM
Hi!
Thanks for this valuable information. That was of great help.
Thanks & Regards
Sgy
