01-29-2013 06:36 AM
Hi all,
Is there a way to disable the "sequence analyzer" programmatically in teststand before execution of client sequence?
04-30-2013 09:48 AM
you can click on the sequence analyzer options icon, then uncheck analyze file before executing.
05-02-2013 12:14 AM
Thanks for your suggestion.
But actually I wanted to disable the sequence analyser programmatically using TS APIs or some other best method.
01-15-2019 05:59 AM
I am fighting with the same problem.
Is there a way to do this by Teststand API?
01-16-2019 05:16 PM
Why are you trying to disable the sequence analyzer programatically? You can have the analyzer disabled and simply manually analyze by clicking the analyze option.
Best,
Ben
01-17-2019 12:50 AM
I have custom User Interface instead of TS interface.
01-18-2019 07:36 AM
Thanks for the information. My colleague who had worked on a similar issue informed me of the following information. I hope it helps!
The programmatic way to disable the sequence analyzer is through the XML file that corresponds to your UI. There is no way to do this through the API, so it will need to be done through a code module. The SeqEdit.xml can be modified programmatically to disable the sequence analyzer before the sequence editor initializes as shown below:
<AnalyzeSeqFileBeforeExecutingOption classname='Bool'>
<value>false</value>
</AnalyzeSeqFileBeforeExecutingOption>
Note that the file is located in a user-specific file which means that it will change if another user logs in to the machine
C:\Users\%userprofile%\AppData\Local\National Instruments\TestStand 2017\SeqEdit.xml
Best,
Ben
