01-13-2021 05:09 AM
I pass some parameters to a sequence in a loop. Some of these may or may not exist depending on the loop.
Is it possible to pass optional parameters to a sequence? So that a parameter can either exist or not.
01-25-2021 01:21 AM
could this discussion be useful for your problem?
https://forums.ni.com/t5/NI-TestStand/How-to-skip-a-step-programmatically/td-p/1034909
02-05-2021 01:06 AM
How about having a container in your subsequence parameters and passing this by reference?
In your subsequence you can use PropertyExists function to determine what do you have in your container.
Something like this you have in callbacks e.g. check how step results are passed to the post result callbacks: sometimes in your result you have number, sometimes string and sometimes pass/fail status.
