12-03-2013 02:06 AM
Is there any way to Disable the Popup confirmation Message saying the staiton globals are modified externally from TestStand?
Ramjee V
12-03-2013 09:36 AM
Hey Ramjee,
Unfortunately, I don't believe there is any way to disable the dialog. I saw your other thread about the station globals, and would be happy to try and help figure out a different way to accomplish what you're trying to do that wouldn't require you to keep updating the globals. Let us know if we can do anything to help!
12-04-2013 09:27 AM
It is possible to share the globals across processes so they can be directly modified without going to disk, but I agree with Daniel, there is probably a better way. You might try using TestStand queues or notifications instead. They can be accessed across processes if you put an '*' character in front of the name. They can also be created and/or accessed programmatically as well as using the synchonization step types. See Engine.GetSyncManager() API help and the synchronization step type help for more details.
-Doug
