NI TestStand
Deployment
I have the TestStand Development System licence (TestStand V4.1).
I would like to deploy my tests. With the deployment tool, I have the possibility to include TestStand engine. The problem is that the deployment package is more than 300 Mb instead of few Mb without TestStand engine. But if I do not include TestStand engine, I have to install the TestStand Development System on PC while it is not a development PC  but a PC in charge of executing tests.
What is the solution ?
(4,047 Views)
why dont you create a system deployment which is just your TestStand engine and UI and test deployments which contain just your test sequences file, code modules etc.
regards
Ray Farmer
Regards
Ray Farmer
(4,045 Views)
I have made 2 deployment package : the firt with the engine, the second with the sequence test.
I install the engine package then the sequence test package.
When I run the sequence, I have this error :
Notice that when I use a full package (engine + sequence test), I do not have this problem.
What can I do ?
Thanks.
(4,022 Views)
you need to attach any picture as attachments otherwise no body can see them.
Regards
Ray Farmer
Regards
Ray Farmer
(4,020 Views)
Sorry 😉
Please see the attached file with the error.
(4,018 Views)
