Deployment utility crash report
Hi, I'm having trouble with the TestStand deployment tool. I have created a functional sequence and workspace, which I want to deploy on a production PC. I open the deployment tool, select my workspace and analyze the source files. The Deployment utility crash report window appears.
Have you encountered it?
(804 Views)
Accepted by topic author Radek-)
If I do not check Enable debugging and tracing in the LabVIEW adapter configuration, then the TestStand Deployment utility does not crash.
(766 Views)
Hi ,
I'm not sure , but you may have problems with Debug Deployment license. Are you sure you have all the necessary licenses activated ?
You can check the TestStand Licensing Options by this link.
Hope this helps.
(715 Views)
