NI TestStand
Deployment passes but VI still not loadable
I want to build the VI`s for a Rohde&Schwarz RTx Oscilloscope to a .lvlibp to use low level commands in teststand. (I also did this before with power supplies etc.).
The reason for doing this is to distribute the code with only a single file.
The build passes and a few VI`s are working (initialize and close)
RTB2000.lvlibp\1abvi3w\instr.lib\Rohde&Schwarz RTx Oscilloscopes\Public\Initialize.vi
But other files are not working, it seems to be something with the folder structure?
RTB2000.lvlibp\1abvi3w\instr.lib\Rohde&Schwarz RTx Oscilloscopes\Public\Generator\Waveform Generator\Function Generator\Configure Waveform Generator Frequency.vi
Can anybody give me some tips? Or maybe a better method for doing stuff like this 😉
(1,203 Views)
Hello tvervecken,
Did you perform deployment by the same steps described here: What Do I Need to Deploy TestStand Code with LabVIEW Modules on Another Computer?
If yes, so will be better if you open a service request and get a solution from NI technical support. And then put here that solution for other users.
Best Regards,
(1,163 Views)
