NI TestStand
Delete results if user wishes to repeat the last test
I am trying to set up a user pop-up to ask them if they would like to repeat the last test that failed. If so... delete the result and run the sequence again.
Can anyone see what I'm doing wrong?
Chris
Message 1 of 8
(5,508 Views)
Accepted by beam7
Have you seen this example?  Does it work for you?
https://forums.ni.com/t5/Example-Code/Deleting-Results-of-Re-Executed-Steps-in-TestStand/ta-p/363667...
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 2 of 8
(5,492 Views)
That works...
Thanks jigg
Message 3 of 8
(5,464 Views)
Hi Jigg,
I have put tried the link you sent me and made a *.seq but it fails the overall result if i fail one of the tests, retry and then pass on 2nd attempt
can you see what I am doing wrong
(For some reason i had to re-name the *.seq to *.VI so you would need to rename it back)
Chris
Message 4 of 8
(5,377 Views)
sorry for some reason it will not let me send the seq
will carry on trying...
Message 5 of 8
(5,375 Views)
you will need to rename the file to retry.seq
Message 6 of 8
(5,374 Views)
Accepted by beam7
Add this to your PostExpression of the Message Popup Step in your SequenceFilePostStepFailure callback:
RunState.Caller.SequenceFailed = (Step.Result.ButtonHit == 2)
Hope this helps,
jigg
CTA, CLA
testeract.com
Message 7 of 8
(5,364 Views)
Thanks Jiggawax
Message 8 of 8
(5,330 Views)
