Database loogging with TS : postgresql
Currently thinking of using native database logging capability of TS, I was wondering if somebody already tried it with PostgreSQL ?
If so, can I directly use one of default schema listed in the Database options ? Otherwise, would somebody share its schema withe the community ?
Thanks for your replies !
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
Message 1 of 8
(6,636 Views)
Thank you for posting on National Instruments' forum.
I send you information about PostgreSQL. I hope it will help you.
http://www.postgresql.org/docs/8.1/static/app-psql.html
http://labview.ni.com/docs/proposals/2010/DSC/LoggingTo3rdPartyRDB/index.html
Brice S.
National Instruments France
Message 2 of 8
(6,618 Views)
Thank you Brice.
The first link is good... for somebody who didn't know Postgres at all before.
The second link is broken... and for what I see, it concerns DSC database logging...
I was wondering about how to build/reuse a schema in the TS database logging option...
Message 3 of 8
(6,615 Views)
Ok,
So, You want to know how to build a schema in TS database option. If I understood your problem.
I found a link on the designing of shema in the TS database option.
http://zone.ni.com/devzone/cda/tut/p/id/6484#toc7
If it is not the answer. I can still help you.
Brice S.
Message 4 of 8
(6,610 Views)
Did you make any progress with this? I am interested on it
Message 5 of 8
(6,424 Views)
Hi Jose,
This post is a bit old, so yes I made some progress with it !
Basically I reused MySQL schema, and made some little modifications to fit PostGres requirements on some sql resquests. Then it works pretty well !
Message 6 of 8
(6,421 Views)
Good to know. I am on my baby steps with that but I'll contact you when I get there. Do you mind if we talk one of this days?
Message 7 of 8
(6,417 Views)
As long as I can answer, I don't mind ! Smiley Happy
Message 8 of 8
(6,412 Views)
